Manual Record?
  • 4 Replies
  • 13437 Views
  • 3 Likes
addertay
I am thinking as with other Arlo models the Ultra will not record motion while in live view. Is there a manual record? I am not seeing the video or snapshot button that was on the Pro/Pro 2.
st_shaw
Master Master
I see the same behavior on iOS.  However, via the web interface the recording buttons are active whether or not local 4K live streaming is active.
I believe  it's because the web interface doesn't do local 4K live, and when the iOS is is streaming locally, the stream is going direct from the camera to the phone, and not going to the cloud, and therefore cannot be saved to the cloud.
st_shaw
Master Master
The record and snapshot buttons appear when live view is active.  I believe you need to have your smart subscription setup before the buttons appear though.
addertay
You are correct... Sorry. Seems when local live 4k streaming is turned on it disappears from live view but when it's turned off it is there.
st_shaw
Master Master
addertay
Yes. This was on the IOs app.
  • 4 Replies
  • 13437 Views
  • 3 Likes
