@Re_zeekay wrote:
Manual record icon disappears. Sometimes it is there, sometimes it isn't.
Do you have 4K livestreaming enabled?
Manual Recording is only available for 1080p. 4K livestreaming requires you to be on your home wifi, and the app will fall back to 1080p livestreaming when it doesn't think it can do 4K.
Not sure, but that might result in the icon appearing only when the stream is 1080p, and disappearing when it is 4K.
When it occurs, if you logout and back in again does it reappear?
Thanks for solving my query.
Accessing Local Storage
