Hi @Retired_Member
After your free trial expires, a smart subscription is required to utilize the cloud recording feature. You can find more info here: What are the available Arlo subscription plans and how much cloud recording is available?
You can also utilize the Local storage feature as well: How do I set up local storage backups on a USB device using my Arlo base station?
Hi @Retired_Member
Accessing Local Storage
