Issue with Recent Ultra Base Station Firmware Update
Matt Skahill
Matthew_Skahill@comcast.net
Try removing and resyncing a camera to see if that helps. Also try a web browser to see if the same behavior happens.
Sounds like a total reset would be in orrder. Remove all devices from Settings, My Devices. You can also hold the reset button until the LED flashes amber if you like. Let the hub reboot and start fresh. Note your settings, modes, rules and schedule before doing this to speed the rebuild.
I have the same issue. After 3 hours of TS with Arlo tech, they stated my problem was due to latest firmware update and caching issue on base. During the TS steps, tech had me remove one ultra CAM to see if that fix the issue with notification and recording. We were unable to add camera back. Did all of the TS steps and nothing worked, Tech stated that same cache issue on firmware may be preventing adding backing camera. I'm told to wait for fix in firmware release.
I only have one base and my remaining 6 ultra cameras are on it. I am hesitate to do a reset fearing it would mess up my subscription. I am still on the old legacy smart premier with 10 camera and 30 days of cloud history.
Well if support is saying that they arlo knows it a problem unless tech was just trying to end the call. Im glad no problems on my hub 4540 which is fine after update. I dont know why there is no statement from arlo on a fix in in the works for you guys.
This has been happening ever since the firmware update, anytime the hub is reset all the settings go back to a basic set. 2K or 4K toggle gets turned off, video settings go to optimized and super wide, brightness go's to -1 setting every time. If the hub gets reset a few times all the cameras quit and can't even be manually re-synced without removing the hub, doing a reset and then re-sync one at a time. Then go and move any over 5 from inactive back to active. Three times now for me.
They better have a lot of hubs if they plan to replace every one having these issues lol
Accessing Local Storage
