How many alerts do I need for a low battery?
I've had to turn off my push notifications as I'm getting many multiple notices from my one low battery camera
You generally only get 1 low battery alert. However, I could see multiple notifications if the level is right at the threshold and the ambient temperature causes the level to rise and fall (I've seen the battery level increase with warmer temps). I'd just go ahead and charge the battery so it's a non-issue in the first place.
Plug the power adapter into an electrical outlet. The camera LED lights solid blue when the camera battery is fully charged. You're Done! Launch the Arlo app or log in to your Arlo account at my.arlo.com. Tap or click the settings icon under the camera that you want to check. Your Arlo camera's battery level displays
Accessing Local Storage
