How can I change wifi networks on an outside camera?
Ultras can only connect to an Arlo Hub. If you want to pair an Ultra with a different hub, then you need to remove it from your account and then re-add it.
If you have a different model (connected to your home wifi), then it would be helpful to know what it is.
Best answers
Accessing Local Storage
