  • 16 Replies
  • 4631 Views
murs01
a week ago, upgraded to Ultra ... replaced system with 3 Pro 2 cameras to Ultra with 3 cameras. Camera are in exact identical location ... yet farthest camera, maybe 40 feet from hub is having problem sustaining connection. Never had any such issue with Pro 2 camera, but now many times during the day the Ultra camera indicates not connected. This is quite disappointing. Also not impressed with after dark performance, think that I was getting clearer pictures with the Pro 2 camera than the Ultra so far, this is disappointing.  Hopefully more tweaks are forthcoming to improve the camera experience
murs01
just a follow-up
been a few days now and no issues with connectivity since relocating smarthub by 1½ feet.
so, indeed small changes can make a big difference
thanks again.
16 REPLIES 16
murs01,
If possible, try relocating your SmartHub closer to that camera. You might also try elevating the SmartHub to improve the signal strength.
murs01
thanks ... again, disappointed that what was fine for Pro 2 is not so good for Ultra, but I will try to move hub a bit closer and higher and see if that helps.
Don't want to have to locate hub to central location, that is not convenient.  Was great for me where it was, near desktop computer.   to relocate would really mean wiring up another area of my home, not a reasonable solution.
but thanks again, I will try ...
murs01,
I certainly understand the frustration. We're taking feedback like this very seriously. The development team is investigating these reports to better understand where can improve.
Please let us know if adjusting location helps.
murs01
only moved SmartHub about a foot and half closer, but at least initally that was enough to improve reception
thanks for the idea
Objects in/on the walls can make a huge difference in reception.
murs01
think you miss my point ...
PRO 2 cameras worked without issue
Ultra camera had difficulty maintaining contact
cameras were in the same position
smarthubs were in the same position
walls and objects were unchanged - same walls, same objects
just differeent camera and different smarthub
And the difference can be small ut exacerbated by that small difference.
murs01
just a follow-up
thanks again.
murs01,
That's great to hear! Thanks for the update!
murs01
This morning, I noticed that none of three cameras are working!
not connected by wifi
will try reboot
murs01
reboot and only two of three cameras discovered
each of the two required firmware update
third camera not discovered and not being discovered
will have to take down installation and try to re-pair with hub
very disappointing performance.
Make sure the battery is charged first.
murs01
batteries were charged, thank you
third camera could not be discovered, even when holding button on camera
had to remove and reseat battery, then got final camera to link to hub
this is just not what I expected from Ultra after flawless Pro 2 performance
murs01
further update ...
actually you were correct ... once reseated and linked ... battery shows 1%!!!!
but never received any warning of low battery
murs01,
A new camera firmware update was released last night.
Arlo Ultra VMC5040 - 1.060.33.7_32761 - 9th April 2019
What was the signal strength showing for your cameras? If the signal strength was low, it's possible the firmware update was attempted and failed, which could cause battery drain.
murs01
One camera wound up with battery drained
Other two were 45% and 75% available
But again none were connected to WiFi
  • 16 Replies
  • 4632 Views
