Hello
So I upgraded to 4K (Smart Elite) and I am happy with the quality. BUT: Unhappy that I cannot view it in any web browser in 4K, except when I download the file.
Shouldn't we be able to play 4K-files (from library) directly in 4K in the browser?
Tried Edge, Edge Chronium and Chrome - they all do not support it.
For this 'Elite' price tag - it should be. Will it be in the upcoming HTML5-Implementation (which is also really needed)
Second question:
- When viewing the cams (live view), they are too only playing in FullHD. I mean viewiing them in a browser = viewing it on a big screen, so it definitly should be viewable in 4K...
Yes I do.
If I download the file, it is correctly beeing shown in 4K on a 4K monitor. It's just not supported by the Browser.
Anyway the flash plugin is ... **bleep**ty. Hope they will replace it soon with HTML5.
Nothing to do with Flash. It's all about the browser and computer hardware. W10 Edge has limited capability - check the FAQ here about 4k compatibility.
The article jguerdat is referring to can be found here: Which devices are supported for HEVC 4K or 2K playback?
FWIW, Edge does play 4K on my laptops and desktops. But as noted, that requires hardware support for 4K HEVC in the GPU.
@Arloultra wrote:
Are you saying you can stream “live view” in 4K ?
I meant library playback.
You habe to turn it on for every camera. It will disable the zoom to movement-feature
						Accessing Local Storage1
						Arlo Mobile App282
						Arlo Pro 31
						Arlo Smart180
						Arlo Ultra9
						Before You Buy434
						Features290
						Fehlerbehebung1
						Firmware Release Notes39
						Installation300
						Online and Mobile Apps113
						Service and Storage110
						Smart Subscription3
						Troubleshooting1,827
