Configuration créneaux horaires
Répondre
Statistiques de discussion
  • 1 réponse
  • 225 visites
  • 0 compliments
  • 2 en conversation
Neofab
Bonjour,
y a t’il la possibilité de configurer des créneaux horaires pour les détections (exemple : 22h-6h et week-end) ?
merci
1 RÉPONSE 1
@Neofab wrote:
Bonjour,
merci
Yes, you can create a schedule.
Note that you are scheduling modes for the base (armed, disarmed), not the individual cameras. If you want to arm some cameras during some timeslots, you will need to also create custom modes. For instance, if you want to arm outdoor cameras at night, but disarm indoor ones, then you need to create a mode that has rules for the outdoor cameras, but not the indoor ones. Then schedule that mode when you only want the outdoor cameras armed.
Also you cannot create a time slot that spans midnight - you need to create a timeslot that ends at 23:59, and then create a second that start at midnight.
  • 1 réponse
  • 226 visites
  • 0 compliments
  • 2 en conversation
