Can't live stream camera
  • 8 Replies
  • 2695 Views
Baoviet
Hello,
All a sudden I can not be able to connect into vmc5040 any more. I’ve tried to remove it and add it several time but no luck. The camera is online with full bar but unable to get access into the camera. Please help. Thanks in advance.
-Truong
8 REPLIES 8
Are you trying to access it via the app?  Or from a PC browser?
When you say "access" do you mean live streaming?  Or something else?
Baoviet
Yes access the camera via app for streaming
Ok.  Does it fail the same way on a PC (browsing to my.arlo.com)
Baoviet
I’ve not try to connect from pc. I will try it from pc and keep you posted. Thx
Baoviet
Hello
PC connection is ok and I can be able to stream live in my.arlo.com but not in arlo secure app.
ShayneS
Are you still experiencing this issue?
If you are still seeing this - Do you have 4K livestreaming enabled?  If yes, does it still happen if you disable it?
Baoviet
Yes 4k is enable and it wont be able to connect and the connection is fine with 4k disable. Thx
  • 8 Replies
  • 2696 Views
