CVR FAST FORWARD FEATURE ULTRA
Hello Arlo Users,
I have the CVR subscription on my camera but unfortunately something happened outside my home and it occurred within a 48hr time frame. I really do not want to sit for 48hrs to detect the action. In addition, the motion detection did not pick it up. Just trying to find a way where i can fast forward throughout the day to see any movement. Thank you.
Using the app, you can expand the timeline via pinch zoom and use your finger to advance the display. The web client works differently but is basically the same sort of thing. There is no fast forward so you do it manually - you don't have to watch it at 1x. Be creative in how you advance the timeline - you'll find the action although it would help to have a general idea of the time action happened.
Accessing Local Storage
