Base station SD card issues vbm5000r4
Basically every sd card put into the device show as unformatted even if I manually format as fat32. If you format through the hub it says formatting for 2/3 seconds then says requires formatting. Please help.
What size drive? It has to be at least 16GB.
Accessing Local Storage
