The major issues being discussed in this thread have been resolved with the most recent Ultra Camera and SmartHub firmware updates. Please check here to make sure your systems automatically updated to the latest versions:
Arlo Ultra VMC5040 - 1.070.50.2_205_0c7c8e1 - 19th December 2019
Arlo SmartHub VMB5000 - 1.15.0.4_297_aa40f04 - 18th December 2019
If you're having a different issue, please open a new thread here in the community, reach out to me in a private message directly or contact support to further investigate: Arlo Support Team
A big thanks to the community for helping our engineering team troubleshoot these issues and thank you for your patience while we worked to release these updates.
I'm having the exact same problem. This is very annying. @JamesC When will a fix be deployed?
My issue also started a couple of days ago. Apparently others are having the same issue. This is very annoying. I have had to disarm my cameras, because I am being inundated with alerts. It's now the waiting game for Arlo to fix it.
nothing works properly!
Activity zones doesn't work even my cameras are always wired, smart notifications are all over the place, pets are persons, light from cars On the streets are persons, actual people ar only motions!
Sometimes my cameras record videos in pink colors! Sometimes they doesn't record at all And i have to restart base station to make them record again! They just advertise system with all those fancy extras but none of them works properly!
All my cameras has strong connection strength also!
"We noticed that the SD card in your Arlo Arlo Ultra 4K is full.
You will no longer be able to record video clips to the SD card. Please go to the Arlo mobile app to delete older activity and re-activate storage of new recordings."
Well I've just stopped receiving notifications now. This is very disappointing.
Try removing power from your SmartHub, reapply power, allow the system to boot back up and test again to see if you still experience the same behavior.
Still not working. @JamesC this is very annoying. Have you received any update from your development team as to when a fix will be deployed?
I have exact the same problem. Cameras keep detecting motion. Never stop. I get 5min recording every time. It started after firmware update last night which says motion detection "improvement". Unplug, plug base station, remove battery from camera... never work. Sometimes camera become offline. CVR stops recording... Too many issues.
Does it do record every movement on day as well or night only ?
Now they detect light beams, cars etc... but less people which is unacceptable
I also have the same problem with triggering, trigger for everything, lamps, movements, 100 meters away and so on, seem also it has started to trigger on sound, because in some recordings I cant see anything, its only noise, but the recording says movement. Some videos are up to 5 minutes of recording without any specific movements and so on...
This started 3/12 for me...
RBK53| Orbi Router + 3 Satellites
Arlo Pro 2| 5 cameras
Arlo Ultra| 3 base stations and 6 cameras
Some users might benefit from this detection but i bet not most of us!
As i see arlo is capable of this kind of motion detection, Would be good to have an option to switch in between motion detection modes!
I hope that's not that case! The waiting game for a fix continues...
Accessing Local Storage
