Arlo ultra-connects won’t stream
Hi I’ve upgraded my system with a single Arlo ultra hub and single camera.
all my old camera connect and work perfectly.
the ultra camera connects but won’t stream, I have:
turned the base on and off multiple times
disconnected the base and started again multiple times
disconnected the camera and reconnected multiple times
move the camera to different locations and signal strengths
changed a settings on the camera
disconned all wiring to hub and reconnected
connected camera automatically and manually.
ithink this one is a dud, bought it from an on line shot so how do I do a return if needed.
seems like I may have wasted my money
Myzoom,
Are you seeing an error message when attempting to live stream? What happens that is preventing you from live streaming? Does the camera record on motion?
For all returns and exchanges, you must contact the seller and refer to their policy.
Accessing Local Storage
