Arlo recording issue
  • 1469 Views
M0ere007
Hello
Since Wednesday, my Arlo Ultra’s are not saving any recordings anymore. I’m getting move alerts, but there are no recordings. I’ve never had an Arlo Secure subscription, but recordings were always saved fine.
Anyone knows if there been a change sinds Wednesday that a subscription is now needed to have video saved? Or do I need to look elsewhere for a solution.
Thanks!
Have you tried restarting your smarthub?
Were you using direct access to local storage?
You do need a subscription to get cloud storage on the Ultra - but some Ultras were offered with a year trial subscription.
If you could see recordings on a PC (my.arlo.com) before, then you must have purchased one of those.
It's likely that your trial subscription that came with the cameras has expired. A sub is required for cloud recordings. Check your subscription status in the app to verify that no trial sub is noted.
You could set up local recordings on the hub (in the hub settings) but it's not like the cloud recordings. Better than nothing but...
M0ere007
@jguerdat @StephenB
Thanks both of you. This must be it. My ultra’s are +- 1y old.
I’ve signed up for a subscription and now it’s recording again.
  • 1470 Views
