Arlo VMB5000 Ultra base station Flicker Adjustment keeps resetting to Auto 60Hz - won't stay on 50Hz
Arlo VMB5000 auto 60 Hz, I want to change setting to 50Hz, I can change it but it won't stay on 50Hz. My other 2 Ultra base stations are on Auto 50Hz, why is this one set as Auto 60Hz? thanks
@Sheppeyboy wrote:Arlo VMB5000 auto 60 Hz, I want to change setting to 50Hz, I can change it but it won't stay on 50Hz. My other 2 Ultra base stations are on Auto 50Hz, why is this one set as Auto 60Hz? thanks
I'm guessing you have 50 Hz power? Auto means exactly that. The (60 Hz) bit is just telling you what it has detected.
Did you try swapping the power adapter with a different base, and see if the problem moves with the adapter? If that doesn't change the symptoms, you could also try moving the base to a different outlet.
Also, are you seeing any issues with the flicker in the recordings or live stream?
Thanks, tried swapping base station and power adapters, problem seems to follow the base station but in UK its 50Hz, other 2 base station say auto 50, do see slight flicker on cameras connected to that base station, thanks for advise
You might try swapping the power adapter with another base, and see if the problem moves.
Accessing Local Storage
