Arlo Ultra no longer recording after being charged
After charging one outside camera it has stopped recording. It worked fine. Now shows motion but does not record .
A different camera only records 14 seconds. It doesn’t record entire sequence of motion detected.
Reboot the hub. Reinsert camera batteries to reset back to a known config. Test your motion detection to understand where motion is detected and where it isn't. Consider a timed recording rather than "record until motion stops".
Owned system for a month. Charged camera in backyard. Went to put it up. Couldn’t connect to position camera. Took camera back inside. Tried to connect lol around the house including near the hub. Will not connect. Removed battery and shut hub off Still nothing. Changed battery with another camera. Nothing. Put it up. It takes a picture. No video. 2 weeks later I still can’t connect to camera. I believe camera is bad
Either return to place of purchase or contact Arlo support for possible warranty or help
Accessing Local Storage
