FWIW, I have one Ultra (recently upgraded to XL) connected to a solar panel, and that has stayed at 100% charge, despite the winter weather. I've also seen some odd (likely false) charge percentages from various cameras over the past couple months. That could be caused by the camera firmware, base, cloud, or the app.
I don't see how the app could cause battery drain - that sounds more like a hardware or firmware issue. What battery life are you seeing on the Ultra with the panel disconnected?
@Tonyschawks wrote:
The Ultra without solar last 3 weeks. I mentioned the App because there is no way to update the firmware without it. Do you know if a firmware is in the works? I have the Ultra pointed in one direction and my Pro 2 in another at the same location. I have no issues with the Pro 2 draining the battery but the Ultra completely drains in a few days.
It would be helpful to know the battery life of the ultra with the problem when the panel is disconnected.
Also, it would be useful to know how about many minutes of video are being recorded every day. If you use activity zones, you need to delete them in order to estimate this.
@Tonyschawks wrote:
The battery without solar last 3 weeks. I have the video fixed to record only 25 seconds which is about 20 times a day.
So about 500 seconds per day (about 8-9 minutes). No activity zones?
Is the Pro 2 also on a solar panel?
@Tonyschawks wrote:
What is FWIW?
For What It's Worth
@Tonyschawks wrote:
When you state it is a firmware issue how does a customer resolve this?
To be clear - I said it didn't sound like an app issue, if it was software it would more likely be firmware. Note I don't work for Arlo, I have no idea on whether they've identified a firmware problem that they are fixing.
Since my own solar panel doesn't create the drain you are seeing, it is more likely still that the problem is a defective panel. If you have a subscription, you could use the phone support option in the app.
Accessing Local Storage
