Arlo Ultra camera not charging
- Email to a Friend
Has anyone found a fix yet for the cameras not charging?
You know you have this issue when they sit on 1%-2% or 3%. Been running around for MONTHS trying to get this fixed, but get stuck in a loop with support. They only seem to want to charge off the solar panel.
Are the Arlo cables known to be faulty?
- Email to a Friend
Just bought these.
Much cheaper than the Arlo branded ones, which seem like they are not very good anyway. Non-genuine ones cant be worse. If nothing else they will be long enough to connect to main power.
- Email to a Friend
I replaced the charger with one that puts out a higher wattage, and also replaced the cord with a shorter one. It's been workinh well for several months now.
