Arlo Ultra Solar in black?
Will the solar panels for the Arlo Ultra be available in black? The pre-orders I see all show the white model. Thanks.
ColoArtist,
At this time, the Ultra Solar Panel is only available in white.
Thank you for your reply.
I'm planning on getting the Arlo Ultra cameras in black. Is there a version of the Ultra solar panel in black planned for production in the future? I can wait for the panel if it isn't rolled out at the time the black Ultra cameras are released. But if a black version isn't in the works I'll probably go ahead and go 3rd party for the panel.
Take care.
A Sharpie or some black paint might be adequate and would remove issues relative to use of 3rd party devices and your warranty.
Thanks for the tips.
However, if there will be one available in black I'd rather wait for it than mess with painting the white one. But your point about 3rd party accessories is a good one. I guess it wouldn't be too hard to mask off the panel and spray the rest. Looks like that'll be my plan B.
Accessing Local Storage
