Arlo Ultra + Smartplan Question
- Email to a Friend
Currently, I'm on the 1-year Premier trial plan that came with my 4-cam Ultra setup. I was wondering if anyone noticed a big difference in their recording playback when they upgraded to the Elite Plan on their Ultra's?
Specifically during evening/low light recordings. I don't necessarily have much hope because when I see the camera's video during local 4k live streaming, it's not particularly great where I'm at.
Just curious to get some advice from someone who might know! Thanks in advance!
- Email to a Friend
Premier gets you 2k cloud recordings while Elite gets you 4k. The actual utility of the higher resolution still boils down to how you have your cameras set up, what the distance to objects are as well as the compression used for any of the videos. If you upgrade to Elite and aren't satisfied, you can always downgrade immediately to save cash.
