Arlo Ultra SmartHub not recognising. Tried disconnecting and reconnecting but flashing orange.
  • 2 Replies
  • 1504 Views
Joshpolso
Have tried turning modem, router and smart hub all off and turn them on in sequence, disconnecting and reconnecting all the cable and resetting the smart hub. Orange light will stay solid for a minute, come to solid blue for a second or two and then flash orange. Any ideas?
Connected via Ethernet straight into router.
Joshpolso
Thank you mate! Left router plugged in overnight and reconnected power this morning and it decided it was going to work first go, but have moved them a bit further away to try and stop any interferences.
If the Hub is close to your wifi router, move it away as far as possible.
Joshpolso
  • 2 Replies
  • 1505 Views
