Hi. I’ve just purchased my first Arlo Ultra 3 camera kit and I’m waiting for delivery. I’m looking at purchasing extra screw-in mounts for a little added security.
Do I need a specific mount for the Ultra?
Will a mount for the Arlo Pro 2 or 3 work?
All advice or links for results are welcome. Thanks.
Generally, any screw mount will work, especially on the Ultra where the screw mount and power connections are widely separated, unlike the Pro cameras.
The screw thread is the same industry standard that you will find on most photographic kit.
Just another user
Thanks jguerdat. I appreciate your help.
Thanks michaelkenward, I appreciate your help.
Accessing Local Storage
