Arlo Ultra SD Card
- 2
Hey
Is there a Size limit for the inserted SD Card?
Can i put a 128GB card?
What is the reccomended size ?
THanks
Daniel
Hi
I use SanDisk microSD cards almost exclusively for everything these days, including as my external portable storage. I am awaiting delivery of the 256GB, 512GB, & 1TB cards, but have tested a number of other sizes. The results of these tests are as follows:
SanDisk Extreme PRO microSDXC 32GB Class 10, UHS-I, U3, A1, V30 (100MB/s) - OK: Works without an issue
SanDisk Extreme PRO microSDXC 64GB Class 10, UHS-I, U3, A2, V30 (170MB/s) - OK: Works without an issue
SanDisk Extreme PRO microSDXC 128GB Class 10, UHS-I, U3, A2, V30 (170MB/s) - OK: Works without an issue
SanDisk Extreme PRO microSDXC 400GB Class 10, UHS-I, U3, A2, V30 (170MB/s) - FAILS: Reports an error < 16GB
A friend of mine uses the Pro3's and has the VMB4540 SmartHub with the USB external connection option. He has a 1TB external USB 3.0 drive connected without any issues, but has not tried a larger drive yet.
I shall expand on my list once I get hold of the other sizes.
Interesting to see, and good to know, the 512GB is working for you when my 400GB one doesn't. I've only recently got my Arlo's so I was expecting some teething issues with SDXC storage options, and as I use SDXC cards as my external "portable" storage options anyway (easier than lugging around an external SSD/HDD) I was hoping to leverage one of my existing cards - currently the 128GB.
I'd very much like to benefit from more local storage when I'm away so hoping the cards on order arrive soon.
I would try the following if you haven’t already: remove the 400GB card from the hub, reboot/restart the hub, reseat the card and then reformat the card. SanDisk cards are quite reliable and like you, I, too, use them exclusively. I hope this helps.
Jijma
- 2
Accessing Local Storage
