Arlo Ultra Charging Cable
  • 2 Replies
  • 2025 Views
Retired_Member
Not applicable
What length of magnetic charging cable comes with an Ultra kit?
From pics it looks short. Is cable in kit the same as the 8ft indoor charging cable you can buy as an accessory?
Also I'm confused about the difference between the indoor and outdoor cables.
I want to plug the adapter end into an indoor socket in my garage and run the charging cable through the wall to continuously power a camera on the other side of the wall.
A 25ft outdoor cable is overkill length wise for my needs. Is the magnetic end of the indoor power cable weatherproof? Looks like the shape of indoor and outdoor magnetic ends are different but from what I've read there seems to be no additional weather proofing on the outdoor magnetic end.
So my question can I safely use the indoor charging cable to power an outdoor camera as long as the USB end of the indoor charging cable is connected to an indoor power socket?
The supplied cord is only about 3 ft +
Outdoor supplies are weatherproof, indoors are not
Last question is yes... as long as the indoor supply is in a dry place
Retired_Member
Not applicable
Fabulous.
Im happy that an 8ft indoor charging cable plugged in indoors with the cable through the wall hooked up to an outdoor camera will work OK.
Thanks for the quick reply.
  • 2 Replies
  • 2026 Views
