I have three Pro 2 cameras on my hub. I purchased the subscription to save images. If I wish to add a couple of Arlo ultra cameras do I need another base or will they connect to the internet themselves?
Ultra and Ultra 2 cameras need a base - they cannot connect to your home wifi.
If your base isn't compatible with the Ultra, than you would need to get a newer one (preferrably a smarthub). You can find out if it's compatible by looking at the info here: https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
Alternatively, consider the Pro 4 camera - it is only 2K, but it can connect either to your home wifi or a compatible base.
