- English
- Arlo Forum Discussions
- Partner Integrations
- Alexa Show 8 Gen 2 wont connect to Arlo Ultra 80% ...
Alexa Show 8 Gen 2 wont connect to Arlo Ultra 80% of the time. Just times out.
My Amazon echo 8 will show me one of my ULtra caeras, 80% of the time. It showed me the other one when I first set up Alexa, but now just times out.
It works fine on my desktop and android.
@ollewis wrote:My Amazon echo 8 will show me one of my ULtra caeras, 80% of the time. It showed me the other one when I first set up Alexa, but now just times out.
Have you tried removing the Alexa app and reinstalling it since it otherwise working with Arlo on App and Web Portal.
yes, not working still
Should also mention one of my arlo is working
Hi ollewis,
If you're still having problems with the Arlo Alexa skill not working with one of your cameras, please contact the Support Team so they can further investigate the issue you're experiencing. You will find several options for contacting support in the provided link.
AppleTV
21 -
Samsung SmartThings
59 -
Security System
