Accessing local storage (SD) via network cable or USB
  • 2 Replies
  • 3721 Views
  • 2 Likes
STTH
Is it possible to remotely access the SD card on the Arlo Ultra hub? The hub is connected to a network switch via a standard Ethernet cable. One would imagine that it would be possible to view the storage from the hub remotely on the PC via the adequate driver. Also, is it there a USB port on the Arlo Ultra hub, which can be connected to a standard PC, in order to access the SD card from the PC? That whould be easy to implement within the Arlo firmware, so I really hope it works. The whole idea being to allow remote access. Having to eject the SD card to then physically attach it to a computer is not an option when you are away.
Not yet. Later this year.
STTH
Should we assume that it will be implemented via a firmware update (since it really should not need any hardware upgrade)?
Just a matter of giving your developpers enough time to code that module into the Arlo firmware?
If so, I really can't wait! That would be the ultimate feature making this product a really complete security package.
  • 2 Replies
  • 3722 Views
  • 2 Likes
