4 Arlo Ultra Cameras, One Burns Through Batteries.
  • 1 Reply
  • 832 Views
ctrad64
One of my 5 cameras burns through batteries. Why? How can I change that?.  In the house it seems to work well but outside I’m charging it every 4 days or so.  While outside I’m only getting one notification a day on average.  Not a high activity area.  Is it picking up motion outside of the activity zone, not reporting it and at the same time depleting the battery?
Thanks,
Cory
That will happen.  If the camera is battery powered, then every time motion is detected, the video is streamed to the cloud - which determines if the motion is inside or outside the zone.  So that will deplete the battery.  Cloud activity zones will reduce notifications/recordings, but they won't improve battery life.
The simplest way to check for that is to turn off the zone on that camera for a while, and see how many recordings you get.
You can also try swapping the camera with a different one, and see if the problem moves with the camera or not.
  • 1 Reply
  • 833 Views
