- Email to a Friend
One of my 5 cameras burns through batteries. Why? How can I change that?. In the house it seems to work well but outside I’m charging it every 4 days or so. While outside I’m only getting one notification a day on average. Not a high activity area. Is it picking up motion outside of the activity zone, not reporting it and at the same time depleting the battery?
Thanks,
Cory
- Email to a Friend
That will happen. If the camera is battery powered, then every time motion is detected, the video is streamed to the cloud - which determines if the motion is inside or outside the zone. So that will deplete the battery. Cloud activity zones will reduce notifications/recordings, but they won't improve battery life.
The simplest way to check for that is to turn off the zone on that camera for a while, and see how many recordings you get.
You can also try swapping the camera with a different one, and see if the problem moves with the camera or not.
All Replies
- Email to a Friend
