have they fixed the issue on the ultra 2 base station so you can view the sd card on my phone without taking it out of the base ?
This has been working with my own VMB5000 base (though I don't think it was ever actually broken).
This works for me only if my mobile and arlo base station are on the same network ie home
It doesn't work with android over VPN the last time I checked and it doesn't work with a PC browser.
I bought my Ultras early on the basis that Arlo would develop access to files on the SD card. I envisioned access similar to cloud with some limitations but was sorely disappointed in just how lacking their final implementation was.
Yes, and it never has.
I also saw this when I was running Android last year. Now I'm using an iPhone, and VPN does seem to work there.
Have you tried setting up port forwarding?
this will be on my home network. so i will be able to view the sd card video library while i am outside the house?
i thought there was a firmware update was supposed to fix this
If you set up port forwarding or use a VPN.
Some downsides when compared with cloud storage:
- No access from the web ui
- No access from friend accounts
- No manual recording
- No thumbnails
so i guess these cameras are going back to the store .
i dont want to pay for cloud storage
Agreed; It has always been a half baked solution. Which is my point, the whole local storage implementation is disappointing and this is just another aspect of it.
Hmmm, interesting. Presumably with the same router? Yeah I heard iThings work OK but presumed that was also with an iThing router but I know little about iThings. I've had contact from Arlo and given them quite a bit of info and suggestions but have heard nothing back. My android DOES work to see local storage if it's on the same local network as the base station.
I'd be interested to know what router you have your VPN on and whether the VPN IP address of the phone/client is in the same network as the base station and home network ie Your base station would be on your home network, eg 192.168.1.0/24, with something like 192.168.1.20 but your VPN may give your phone a different network eg 10.1.1.5 or same network eg 192.168.1.21.
Nah, I'm a bit reluctant to hang my base station out on the internet for the world to try and hack. Arlo have not demonstrated enough transparency or credibility for me to trust exposing a black box on my inside network directly to the outside world.
I use OpenVPN, hosted by my Netgear Orbi router. My home network is configured as 10.0.0.0/24; the VPN connection also uses a 10.0.0.0/24 IP address.
The router and VPN didn't change, the only difference was the shift from Android to iPhone.
It's worked for me so I think they've fixed it. I was able to access videos on my base station (SD card) using my mobile network here in Scotland.
(Android phone, Draytek router with SSL VPN set up)
That's good to hear. VPNs are (IMO) a more secure approach then port forwarding.
I still had to have the fort forwarding function on in the app. But not on the router I don't think.
Could someone check out whether this works or not?
Arlo Ultra 2
Prima di acquistare
