I have model VMB5000version 6.3.4 running on IOS 18.6.2
Could you all please add back the feature where you can disable a base station. This is extremely helpful and time saving when you have multiple base stations or a system at another house. I know you can place cameras on standby or disable them all but in some situations you don’t want ALL cameras disabled. And please work on deleting feeds. There should be a way to see everything instead of having to scroll down to every day to highlight then delete. Better yet would be a calendar you can just highlight each day and delete plus a delete all would be great. I hope you confide these suggestions especially the base station issue.
Hi @Dullboy,
Thank you for your feedback! You can delete videos either one by one or all recordings from a specific date in the Feedtab. Just open the calendar in the top right.
- On iOS, dots appear under dates with recordings.
- On Android, dates with recordings are highlighted.
Once you select a date, tap the circle with three dots in the top right > Select Events > then choose individual recordings or delete all for that date.
Hope this helps!
Thank you for your feedback, we greatly appreciate the community’s contribution. I will provide this information to the appropriate team for future consideration.
Hi @Dullboy,
Hope this helps!
Arlo Ultra 2
Prima di acquistare
