Ultra 2, what does no direct wifi mean?
  • 1132 Views
tecmcord
n/a
It means the camera requires a smarthub/base station - for example the VMB5000.
It cannot connect to your home wifi, only to the base.
tecmcord
so the base station provide its own wifi, 2.4 or 5 and is it secure. Can you set the security to ie WPA-2?
The WiFi is secure, and the system is closed - there are no exposed settings, and you will not be able to join the base station network from your other devices.
The VMB5000 uses dual-band (both 2.4 and 5), and the Ultra 2 can use either.  Again, there are no settings.
  • 1133 Views
