Ultra 2 set up using SD card for storage
  • 1 Reply
  • 768 Views
AndyLatts
Setting up Ultra 2 with sd card.   When going through the set up process I get to ‘storage settings’ it will not then allow me to ‘record locally’. I have an SD card in place ok. Can anyone assist me as to why I can not proceed from this point ?
Try a different card of at least 16GB. Make sure there is only one partition on the drive (use a computer to check and remove them if needed). Formatting in the hub is easier than having to download a utility on the computer to format in the required FAT32.
  • 1 Reply
  • 769 Views
