Ultra 2 not picking up animals
The cams usually have a max of 25 feet for motion. Small animals may be less. You can read the FAQ in the Ultra 2 forum and the link below may help with positioning the cams for best coverage to start with.
I am suffering the same problem with Ultra 2 cams, is there any update concerning this issue? Thanks a lot in advance.
mbejdom,
As mentioned above, camera positioning is important for determining what motion can be detected in your environment. For tips on positioning your camera for best performance, take a look here: How do I position my Arlo Ultra camera to detect motion in specific areas?
I would agree. These cameras are terrible at picking up motion. Mine won’t even pick up most humans walking in what the camera setup image tells me is the motion range.
My two "Arlo Ultra 2" (au2) cameras are great in picking up motions (cats, squirrels, people) and sounds to trigger recordings. I see big improvements in motion sensor sensitivity in au2 compared with my old 1st gen. Arlo cameras.
Arlo Ultra 2
Prima di acquistare
