Ultra 2 has a flashing amber LED
  • 1 Reply
  • 708 Views
Wisey1
Hi all,
My arlo ultra 2 has an amber flashing led and I'm not sure what it means.
The cameras keep saying they are off-line.
I've switched off and on and reset etc but nothing works.
Please help
 https://kb.arlo.com/642/What-do-the-different-LED-behaviors-on-my-Arlo-camera-mean
Also, check the LED(s) on the base/smarthub
What exactly did you switch off/on?
Did you do the factory reset process for both the cameras and the base? If you did a reset, did you also remove the cameras and base from the account before you did the reset, and then add them back afterwards?
  • 1 Reply
  • 709 Views
