Ultra 2 SmartHub vs. Subscription Plan
Was wondering what the ups and downsides are to either of these 2 options. Not a big fan of the subscription price, but it's a no-brainer to check the camera and recordings. Not sure how easy it is to access the same thing using a hub. Understand that a hub plus micro SD will set me back around $200. Hoping to get some clear direction on one or the other from experienced users.
Downsides of direct access to local storage:
- Recordings can only be viewed in the app (not the browser)
- Recordings can only be viewed from the primary account (not shared accounts)
- No ability to make manual recordings or snapshots
- No thumbnails until recording is downloaded manually for viewing
- remote access requires router settings that many find difficult (and which will not work with some internet service providers).
There are of course other subscription features - notably activity zones when on battery power.
Arlo Ultra 2
Prima di acquistare
