Ultra 2 Camera has stopped working even though the battery is good
  • 1 Reply
  • 728 Views
VulcanT
Hi my camera came up with a message to say it was too cold and then it was too hot and then it has stopped working completely even though the battery is good.
Did you try removing the battery and reinserting it?
When you do that, take a look inside, and make sure there is no moisture or corrosion.
  • 1 Reply
  • 729 Views
