What’s going on with the SD card corruption issue? I keep repairing the cards on my computer and the VMB5000 keeps re-corrupting them rendering my local storage option non-functional.
Everything appeared to be working again with the exception of the annoying need to download stored videos to my phone.
An hours later and even after a restart of the base and the app: There was an error obtaining your library. Arlo team is working on this issue.
How much of a later date before the EU get this? Looks like my firmware is quite old but app says it’s up to date.
VMB5000r4
f/w 1.21.0.2_1423
Great question, it looks like there is a current Slow release plan for Your regions firmware. Some users may have this firmware installed OTA as the release is ramped to 100%.
Unfortunately, my USB drive finally stopped recording on 6/23/2023. It looks like the last successful recording was at 4:15pm ET, then nothing. Looking at the drive through the Arlo app, it's not in good shape. The drive is there and I can watch the videos, but I can't do anything else with the drive (e.g. format, view info, etc). When I put the drive in my Windows desktop, it says the USB is corrupt, but then it can't fix it. I can still navigate within the drive, but I've noticed that I can't delete the last folder that was written to (000020); I can delete other folders. Looks like I'm going to have to reformat again. I'll continue to post updates here to my dilemma as it doesn't appear to be completely fixed as I had hoped...
Well I thought this issue was fully resolved but I guess not. My system stopped local recording to micro SD on 30 June despite having local storage selected.
I have cloud storage but I need permanent recordings not ones that disappear after a set amount of time.
I have reset the VMB5000r5 base and verified I have plenty of room on SD card and local recording is turned on.
The latest firmware version for the EU region has been released. Please let me know if you are still experiencing this issue. Your devices should automatically receive the update OTA over night.
Thank you
Yes that’s fixed the sd card issue. Thanks
@Old-dirty Thank you for the update.
For Turkey, this problem is still not fixed and there are serious PROBLEMS. If this is not corrected, I will initiate legal proceedings. We have been very victimized by Arlo. While my 4540 device is running smoothly, it gives a usb error.
@BK-001
Did you receive my direct message regarding the error messaging?
I'm just about ready to give up on Arlo. I've had to reformat my USB drive 2-3 times in the past couple of weeks (after it had worked for about a month straight). Now, I can't get it to work for more than a couple of days. I'll give it one more shot, then this setup is going on eBay for someone else to figure out... So disappointed...
Arlo Ultra 2
Prima di acquistare
