Removing arlo ultra from the shell
  • 2 Replies
  • 1086 Views
Mikeshop
When it is time to charge my battery, I always have difficulty removing the camera from the shell.  When I press the release button, the camera does not slide forward as it should so I can’t grab it and pull it out completely.  If this is true of all the cameras I have. Does anyone have any tips?  I’ve been using a small suction cup. I put on the front of the camera to help me pull it out once I press the release button. There has to be a better way.
You could try applying some silcone grease around the o-ring.
Generally I press the release button once, and pull it out a little bit (though some folks say they shake the camera).  Then I press it again, and pull out the camera the rest of the way.
Mikeshop
The silicone worked. Now it slides out as it should. Thanks for the reply.
  • 2 Replies
  • 1087 Views
