Hi
Is it possible to view ultra 2 or pro 4 cameras remotely (live) when I'm away from home on iPhone without a subscription?
M
@M_kaj wrote:
Do you know if remote live streaming (without subscription) require reconfiguration of your router (I read something about VPN and port forwarding which sounds complicated) or is that not correct ?
You won't need to reconfigure your router, or use a VPN or port forwarding.
You are perhaps thinking about direct access to local storage (accessing a locally stored video library). That is quite different from live streaming the camera.
Best answers
Yes. More information on what features you lose when the trial subscription ends is here: https://kb.arlo.com/000062312/What-options-will-I-have-when-the-Arlo-trial-ends
Thanks Stephen - much appreciated.
Arlo Ultra 2
Prima di acquistare
