Recording issues - Arlo Ultra 2
  • 1641 Views
Benjodude
Why did my Arlo Ultra 2 stop recording?
dcfox1
Need details. But to start do you have smart subscription if your 3 month trial expired for cloud recordings? If you set up local storage on the hub are they there?
Benjodude
Thank you for your reply. It’s my second Arlo system - I had he first generation before and it was recording for as long as I had it. You are correct. I don’t have the subscription so it stopped once the trial period expired. I checked for local storage and I see a micro SD slots but no SD in place. That should be the problem. I’ll get one. Thanks again!
You might check here on how to set it up: https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
There are a variety of limitations, and some aren't listed in the kb article.
  • 1642 Views
