Receiving error when trying to login web. Tried deleting cache, disabled firewall and reset modem.
  • 16 Replies
  • 8396 Views
  • 4 Likes
  • 9 In Conversation
JET11
I continue to receive this error (https://ocapi-app.arlo.com/api/auth: 0) when I try to login to my.arlo.com. Has anyone experienced this and if so how can I fix it.  I have tried deleting the Cache, disabled firewall and reset my modem.  It happens on my computer but not when using the APP on phone or iPad.  I have both an Apple iMac and MacBook Pro which both experience the same error.
Thanks for the help
John
16 REPLIES 16
Do you have internet security software installed on the PCs (or in your router) that might be getting in the way?
Have you tried installing and testing with Chrome?  Or just Safari?
Also, have you tried using logging in from a private/incognito window?
WhoIsAtMyDoor
It has been well over a week since I've been able to log into my.arlo.com.  I have rebooted my computer and tried multiple web browsers, but when I enter my username and password, I just get this in a red box at the top of the page:
Http failure response for https://ocapi-app.arlo.com.api/auth : 0 Unknown Error
This results in all 4 of my cameras being unusable.  Is this a known issue?  Thanks.
@WhoIsAtMyDoor wrote:
Http failure response for https://ocapi-app.arlo.com/api/auth: 0 Unknown Error
Have you tried incognito / private mode in the browser?
Have you installed or updated internet security software on the PC?
I haven't seen this on any of my PCs (using both Chrome and Edge).
WhoIsAtMyDoor
I just tried incognito mode on Chrome - same behavior.  This is on a fully updated Mac.  It's worked perfectly in Safari for several years.  This behavior just started sometime last week.
WhoIsAtMyDoor
I have tried Chrome, Safari, and Firefox.  Same behavior on all three.  Same behavior in incognito/private modes.
WhoIsAtMyDoor
Also note that Arlo Support replied to me today with some things to try...so that's good.  I will have to test it again after work today.
ant
Mentor
Mentor
I got "Http failure response for https://ocapi-app.arlo.com/api/auth: 0 Unknown Error" twice when trying to log into http://my.arlo.com earlier. I finally got in after two attempts for its 2FA to show up.
JET11
I have tried everything you mentioned and still the same
JET11
Has anyone with the same issue using a MAC found a solution?  I am still experiencing this error.
JessicaP
If you're experiencing problems where you're receiving that error, please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
ant
Mentor
Mentor
I never saw it again so I guess it was a random hiccup.
jesmith402
"Http failure response for https://ocapi-app.arlo.com/api/auth: 0 Unknown Error"  Why am I getting this error message when I try to login with my Mac mini. iPad and iPhone work fine !!
jcronin
I been having the same problem I downloaded the cc cleaner browser and can get through on that one. IE, Chrome and Firefox all the the API error.
langlois23
I have tried everything I can think of and as of right now no luck.
dcfox1
What exactly is your problem and what have you tried since this is your first post in this old thread.
ant
Mentor
Mentor
I only get this error in 64-bit SeaMonkey (x64; rv:60.0) Gecko/20100101 Firefox/60.0) in my 64-bit Windows (7 & 10) PCs. I have to use Firefox. 😞
  • 16 Replies
  • 8397 Views
  • 4 Likes
  • 9 In Conversation
