Planning on picking up some Arlo products for the house. I have a few questions and I wanna make sure I understood the information I researched.
Arlo cameras are technically all wireless until needing charge, or you can run the charger to an outlet.
I don't need a subscription unless I want the videos stored on a cloud. I can hook up a hard drive to the hub to store it on that, can I still stream the videos from the HD to my phone while I'm away from home?
I can tap into the camera from home.
Anyone answer if I got these correct?
iktribegr63,
1. Yes. Arlo Wire-free cameras can operate without any wires connected. Depending on the model, indoor/outdoor AC adapters and solar panel options are also available.
2. Yes. For content to be saved to the cloud, you will need an Arlo Smart subscription but local storage is an option. Take a look here for information on how local storage works: What is Direct Storage Access and how do I use it?
3. Yes. You can use the Arlo mobile app to live stream both locally and remotely.
iktribegr63,
Arlo Ultra 2
Prima di acquistare
