I’m interested in purchasing the bundle that includes the wired doorbell, floodlight cam, two Ultra 2’s and smart hub. When I review “what’s included” for the Ultra’s (Item No. VMS5240-200NAS), it states that only 1 mount and 1 rechargeable battery is included. Is this correct?
All the other bundles show the correct number of mounts and batteries for the included number of cameras. Hoping it’s a type-o.
Hi, Do you have the link to the website I can check out? You should receive a mount for each wireless camera.
@WLalle wrote:
https://www.arlo.com/en-us/wired-doorbell-4k-mid-to-large-home-bundle-white.html
That shows two mounts - one magnetic, and one screw mount.
The screw mount threads are standard, so there are plenty of third party mounts that can also be used.
It still shows one battery, doesn't it?
It does say that - clearly a mistake. Tagging @JamesC so it can be corrected.
Thank you for providing this. I have notified the appropriate team. You should receive 2 rechargeable batteries, 1 for each camera in this bundle.
Thanks again, the listing has been updated.
Arlo Ultra 2
Prima di acquistare
