Possible to have camera set up on 2 wifi networks with one hub?
  • 4 Replies
  • 1703 Views
Nik007
I have one wifi for my backyard and one for my front as my property is pretty big. Is it possible to set up 2 cameras on each with one hub? Tia
Your WiFi has no bearing. The hub generates its own WiFi connection for the cameras so you'd need to find a central location that will provide adequate signal strength for all cameras or you'll need to use a second hub (one for the front, one for the back cameras).
Nik007
I thought there was a way to connect directly to the wifi. But if thisnt the case that sucks. But thanks for the help and quick reply. Really appreciate it
You can do that with the Pro 4.  It is a 2K camera, but still worth considering.
Nik007
Thank you but I dont wanna compromise the quality. I'll have to try and figure something else
  • 4 Replies
  • 1704 Views
