One camera in system failing to record
  • 1 Reply
  • 503 Views
Firebrand
Spoiler
I have a system with a base station and 2 ultra 2s. I do not have an active subscription and have it configured to store locally on the base station.
the system worked for about a year but now 1 camera works flawlessly and stores
video to the base station.
However, the second camera has issues. I can access the live feed no problem but it does not store any video to the library. Any ideas?
  • connectivity is strong for the malfunctioning camera and it is hardwired to power so no battery issue
  • It used to work and if I go back far enough in the library it has videos but nothing from the last 60 days or so (it should have a daily vids bc it faces our driveway)
  • There were no settings changes on the camera or the base station during that time that I am aware of, but I also don’t see anything in the settings that would impact the local storage
any help would be great!
Have you double-checked that it is armed?
Also, maybe use the motion detection test to make sure the camera's PIR sensor is still working.
  • 1 Reply
  • 504 Views
