Notification sounds
  • 23 Replies
  • 16721 Views
  • 5 Likes
  • 8 In Conversation
springbokgt
On android 14 I am unable to set a custom notification sound under system app settings. Please assist.
23 REPLIES 23
Edit the phone settings for the Arlo app. Edit the Notifications section and then click on Notifications (NOT the toggle). You can set the sound there.
springbokgt
Thanks @jguerdat for the prompt response. Just to let you know that I'm on Android 14 UI 6.1, not sure if that makes a difference! Should I find the setting under Settings>>Apps>>Arlo Secure>>Notifications? If so, I don't see the setting!
You went to the right place. Look at the attached images - the first shows the screen where you can toggle various notifications (including Notifications itself). The second shows what is displayed when you click on the word "Notifications" (NOT the toggle). You may have to wait for the images to be approved before you can see them but try just clicking on the word "Notifications" to see the place to set the custom sound.
springbokgt
Hi @jguerdat , my view looks different.
Please see the images below:
My Notifications option only have a toggle switch, I don't have the ability to also click the word "Notifications".
What phone do you have? Samsung ones seem to be the most problematic with their customizations.
springbokgt
Samsung Galaxy S24+
For whatever reason, Samsung seems to have made enough changes to not only their settings but to other parts of Android that make it somewhat problematic with the Arlo app.
@JamesC , @ShayneS , @BrookeN  can you illuminate us on any issues getting Samsung devices to play nice?
BrookeN
Thank you for sharing the behavior you are experiencing with the notification sounds on the android device. The development team is currently looking into it. We will update the community when we have more information.
springbokgt
Thank you for your response. I eagerly await your reply.
BrookeN
Are you still seeing this same behavior?
springbokgt
Hi BrookeN,
I'm still unable to choose a personalized notification tone through the Android App's Notification settings. Has there been any modifications made on your side?
M410
I am also having the same issue. I hoped the recent Arlo app update wold fix it but it didn't.  Also on a S24+.
KristaMc
Go to Settings>Notifications>Advanced settings and toggle on Manage notification categories for each app. Then go to App notifications>Arlo Secure>Notification categories>Sound.
springbokgt
Awesome that works! Not sure if I'll be opening a can of worms 🐛 by enabling the "Notification Categories for each apps". I'll monitor it... 👀
PaxMoon
Thanks KristaMc.  I have had trouble with this since I got a new phone, but I followed what you said and now I can change it to an individual notification sound.  Thanks heaps!!!!
Borgmier_17
I tried this same method but I didn't have any success with it.
springbokgt
Hi @Borgmier_17
Are you on the same Android version:
Jeanette70
Ik heb hetzelfde probleem, zou ik graag een aparte beltoon selecteren.
Jeanette70
springbokgt
@Jeanette70 kyk na die boodskap van @kristamc!
Jeanette70
Not working!
BrookeN
Were you able to get your notifications sounds to work?
Jeanette70
No, bought a chime for now
  • 23 Replies
  • 16721 Views
  • 5 Likes
  • 8 In Conversation
