Not able to connect with Ultra 2 smarthub VMB5000. Did factory reset a few times.
I have just purchased Ultra 2 set with 2 cameras, not able connect either via IOS app, Mac/window browser to the smart-hub.
The smart hub is connected to a router via LAN, IOS app/Mac/PC running 2.4 Ghz on same router as required but not able to connect.
Now tried 2 routers still no luck with forced 2.4, with attempts from iPad, Iphone, and browser on windows and Mac.
I did factory reset already few times
Is there a way I can connect direct to the smart-hub use wifi or LAN ?
frustrated, what am I doing wrong?
Odd thing is, cameras connects to HomeKit easy
(Homekit addition deleted again, removed batteries from cameras and did a factory reset)
Hold the hub's reset button for >10 seconds until the LED flashes amber. Let it reboot and try claiming it again.
Thanks 🙂
Arlo Ultra 2
Prima di acquistare
