My local storage stopped working
  • 4 Replies
  • 474 Views
Ablonski
With latest upgrade of the app my storage stopped working. Is anyone experiencing the same? I have Samsung s22 ultra and cannot get local storage while my wife iphone is working well. I contacted arlo but after 2 weeks they are still investigating
If you
  1. go to the devices page
  2. press the tile for the smarthub
  3. select "Storage Settings"
do you see the recordings there?
Ablonski
Getting same error there...
Ablonski
Getting smae error from device settings
I've seen the same thing but I just tried it and - POW! It loaded almost instantly! Part/most of that is likely due to my copying files off the microSD card monthly (I'm using a VMB5000) and reformatting so the card is relatively empty. I suppose that may be an issue, that the number of videos is causing this (a timeout needs to be extended?). In any event it worked great this morning.
  • 4 Replies
  • 475 Views
